Arneson Surface Drive Issues
I'm wondering if anyone else out there has had similar issues as I did converting I/O drives to arneson surface drives. I have an express cruiser Formula 370SS which is a bit heavier 16,000lbs and beam of 10'6" than your typical off shore boat. When I installed the drives over a year ago I couldn't get the boat up on plane. Most of the props made for that drive are at most 18" dia. I was getting too much prop spin or cavitation to push it up on plane. Then I had larger props custom built they were 22" diameter 6 blade 26 pitch. Now I have too much prop and the engines won't turn past 2000 rpm and still can't get up on plane. These props are super expensive as you know and this is a very tedious process. Is there another solution out there that I don't know about? Ric over at Arneson hasn't been any help. Thanks.
You will need a vent tube for your larger diameter propellers to break loose and get the naturally aspirated engines to rev. Bill @ Ateco is making these up he told me as I have been in contact with Bill along the way during this project.
Arneson Surface Drives www.arneson-industries.com
That would be the case if it were true but I don't operate that way. Bill @ ATECO Engines handled the installation and I have been in contact with Bill on a VERY regular basis. Thanks for the confidence.
