exhaust/ head port mismatch? >
Old 05-15-2013 | 11:06 AM
Default exhaust/ head port mismatch?
Does anybody know if its still ok for the ports to be mismatched? My heads are D shaped and the exhaust ports are oval shaped. I have spoken with a tech from Profiler on the this and he said it shouldn't be an issue considering I have thru hull, which means theirs no back pressure. I guess its the issue of not having the same amount of gasket compared if they were matched. The person I bought my exhaust from had the same issue and has been running like this for a year with no problems... I guess I'm just looking for some more feedback... Thanks!
chrisf695 is offline
Old 05-15-2013 | 11:50 AM
No, that is not good. They should match or at least the exhaust manifold should not block any of the exhaust port.
Wannabe
wannabe is offline
Old 05-15-2013 | 04:09 PM
Default fixx
take a round port exhaust gasket and match it up to your heads,,if theirs no obstruction then the is nothing to worrie about..
FIXX is offline
Old 05-15-2013 | 09:44 PM
johnnyboatman's Avatar
I thought the exhaust ports were d shaped, intake would be square , rect, or round.
johnnyboatman is offline
Old 05-15-2013 | 10:57 PM
Default fixx
i think he ment that hhe cylinder heads exhaust ports are D shaped and his manifolds are oval port shaped..
FIXX is offline
