Go Back  Offshoreonly.com > Owners Forum > Eliminator
27 Eliminator on boat lift >
Old 05-15-2013 | 02:43 PM
Default 27 Eliminator on boat lift
Any reason why you shouldn't position the bunks on a boat lift such that they are under the sponsons rather than in the hull indent that's between the sponson and the centre pod (like where the trailer bunks go)?. Reason I ask is the bunks on the lift are not "tall" enough and can't reach up to carry the boat in the intent. Thanks.
bouncedcheque is offline
Old 05-15-2013 | 04:43 PM
Randy Nielsen's Avatar
I would guess you can set it up that way but it would be a bear to center it up as compared to sliding over the rails. Same with the trailer. JMO Randy
Last edited by Randy Nielsen; 05-15-2013 at 04:49 PM. Reason: changed answer to better fit question
Randy Nielsen is offline
Old 05-15-2013 | 08:55 PM
Super easy fix. Get 4 new raises to increase the height.
I had the same issue, had a tech from HydroHoist walk me through converting a vee lift to a cat.
CumberlandDayton is offline
