Hood scoop or......
Old 06-01-2013 | 09:07 AM
Default Hood scoop or......
I'm trying to find a way to fit the new blower setup under the hatch. Not wild about a scoop, but don't see another way. I thought about a sleek smaller scoop facing backwards if I can find one. I've seen some boats with them in the past. I'm at the bottom of the hatch with out carbs and flame arresters. Basically looking for ideas.
Thanks in advance.
cp5899 is offline
Old 06-01-2013 | 11:51 AM
i like scoops but thats just me...
antisocial is offline
Old 06-01-2013 | 12:50 PM
Randy Nielsen's Avatar
You might talk to an engine builder about removing the chiller. You won't have to spin that blower as fast to get the boost you want & with slower blower speed you might run into issues with uneven mixture in the lower manifold after running through the chiller. Plus you won't have to plumb the chiller. I had some extensive conversations about this subject with my whipple set up. Randy
Randy Nielsen is offline
Old 06-01-2013 | 11:50 PM
I don't mind the scoops, but I need something to match the boat. I might go with one of the aero tear drop scoops and face it backwards. Think it may look good.
As for the chiller, its set to spin 1:1 right now and it made 7 psi on a 509 with similar cam specs to mine. I hoping it works good because I love how tall it is. Makes it look more intimidating. In my opinion anyway.
cp5899 is offline
Old 06-02-2013 | 09:42 AM
glassdave's Avatar
Neno the mind boggler
well . . . if ya do go with a scoop placement is critical
saw this at loto one year
Attached Thumbnails Hood scoop or......-p1010109156081535.jpg   Hood scoop or......-p1010001.jpg2113265596.jpg   Hood scoop or......-p1010002.jpg588851181.jpg
08 OPA High Points Champion
glassdave is offline
Old 06-02-2013 | 09:46 AM
Note to self....no scoop on the nose. Looks a bit odd for sure and sure it doesn't help aerodynamics.
cp5899 is offline
Old 06-02-2013 | 07:38 PM
Coolerman's Avatar
PF Marine
wth........
Coolerman is offline
Old 06-02-2013 | 10:29 PM
That looks like a Bayliner Capi with a bad nose habit.
Revd Up is offline
Old 06-02-2013 | 11:16 PM
OEM cabin fan replacement for a VIP also increases bow lift. LOL
Old 06-03-2013 | 03:16 AM
I would refrain from adding one if you could, not only do they look like dik, but less skanks can lay out on the back if you have a scoop cock-blocking you....
keegan is offline
