Vinyl-ester work time
Old 06-03-2013 | 07:51 AM
Default Vinyl-ester work time
How much work time before vinyl-ester starts to kick?
JRider is offline
Old 06-03-2013 | 09:30 AM
Depends on temp, humidity and catalyst ratio. Can be 10 minutes to several hours
Unlimited jd is offline
Old 06-03-2013 | 09:36 AM
c_deezy's Avatar
+1. Different batches have different kick times too and quantity will effect it also. If you mix up say 30 oz in a quart cup it will go off quicker than 30 oz in a 2.5 qt cup or if you pour it in a paint tray. Large quantity in a smaller container will go off quick.
Too many factors to give a specific time.
c_deezy is offline
Old 06-03-2013 | 11:23 AM
What does higher humidity do? Cure faster or slower?
JRider is offline
Old 06-03-2013 | 03:16 PM
when all weight out properly with the mek i averive between 30 to 45 min before it starts to gel up..
FIXX is offline
Old 06-03-2013 | 06:11 PM
glassdave's Avatar
Neno the mind boggler
yep, a good quality VE at aproz 70 degrees will give 30-40 min. I would think higher humidity would speed it up a bit though.
08 OPA High Points Champion
glassdave is offline
