Top mounting starter for a bravo one? >
Old 06-03-2013 | 05:59 PM
Default Top mounting starter for a bravo one?
Does anyone know if there is a bravo 1 bellhousing which will accept a top mounting starter? I broke the phucking outer bolt off in the block and then broke off the easyout trying to get the dam broken bolt out. I tried drilling smaller holes around the easyout with the hope of being able to know it loose. Had no luck with that. I've drilled and drill for 8hours today and i'm ready to give up. I wish it would have been one of the inner bolt. That fix would have been easy. Just looking for some options here guys. Thanks Robert.
crf311 is offline
Old 06-03-2013 | 06:33 PM
Mbam's Avatar
Offshoreonly Advertiser
Not enough room between the back of the engine and the transom
Mbam is offline
Old 06-03-2013 | 07:15 PM
That's what I though. Thanks
crf311 is offline
Old 06-03-2013 | 08:45 PM
If you can smack the easy-out with a hefty punch and a big hammer it will shatter. Done it a couple of times.
zz28zz is online now
Old 06-03-2013 | 09:03 PM
I'll give it a shot in the morning. I just don't want to crack the ear off.
crf311 is offline
