Repainting stripe
Old 06-11-2013 | 08:34 AM
bigboat28's Avatar
Default Repainting stripe
What is the proper procedure to repaint a stripe? What do you sand surface with and clean with to make sure wax is removed and surface is paint ready? If it matters previous stripe is imron and planning to repaint with imron.
bigboat28 is offline
Old 06-11-2013 | 07:51 PM
ive seen a lot of body shop guys wipe it down with prep solvent then hit it with "crystal clear" glass cleaner made by Castle products. are you restoring the pantera?
88bullet is offline
Old 06-11-2013 | 08:22 PM
bigboat28's Avatar
What grit you sand it with? Tim you happen to know the color code for the green Pantera uses? No not restoring already done just changing color of stripe.
Old 06-11-2013 | 09:41 PM
onesickpantera's Avatar
When I had my Donzi repainted I stripped the boat and asked my painter what to use to scuff. He had me use a green Scotch Bright.
onesickpantera is offline
Old 06-11-2013 | 09:56 PM
Imron? Sand with #320 or #400 and scuff with a red scotchbrite. You can use acetone or wax and grease remover to wipe it down. Then go over it with 70% alcohol to remove any residue from your fingers.
POWERPLAY J is offline
Old 07-17-2013 | 12:08 PM
Watch out for static from rubbing on plastic (fiberglass). It happened to me once and caused fisheye looking spots all over the boat. I was told glass cleaner and paper towels just before paint removes the static. I've done two boats this way since and haven't had a problem.
Paralyzer is offline
