496 ho IAC problems what now? >
Old 06-11-2013 | 07:17 PM
Default 496 ho IAC problems what now?
changed it out still have the code on the scanner and 2 beeps every minute. rinda scanner has IAC test mode which gives me an error code, IAC has no communication with the ECM ? any ideas?
c2boatman is offline
Old 06-11-2013 | 07:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Probably a driver issue or hardware issue within the ECM. Call and talk to Dustin at Whipple. He can fix this; as it's somewhat common.
Sydwayz is offline
Old 06-11-2013 | 07:39 PM
ecm
Old 06-11-2013 | 07:40 PM
i was thinking a ecm issue, thought about swapping ecm from the other motor to see if the problem moves
Old 06-12-2013 | 07:38 AM
took the ECM off the good motor, beep is gone, hope someone can fix it without getting a new ecm
Old 06-12-2013 | 08:54 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Whipple Industries
Contact Dustin directly at the link just posted. He CAN fix it, and with overnighting both ways you can be back on the water by the weekend.
Sydwayz is offline
Old 06-12-2013 | 10:58 AM
thanks, will do
