Engine bogging after jumping waves >
Old 06-11-2013 | 08:46 PM
Default Engine bogging after jumping waves
My 454 runs perfect in flat water all the way up to full throttle... When I head out the inlet jumping large waves and the boat goes on a 45 degree angle, when I land the boat starts starving for fuel damn near turning off...any ideas thanks guys
pantera232 is offline
Old 06-11-2013 | 09:06 PM
My fist guess would be to check the float level in the carb
vince1645 is offline
Old 06-11-2013 | 09:38 PM
jeff32's Avatar
same comment!
jeff32 is offline
Old 06-11-2013 | 09:58 PM
the float bounces and causes a brief over rich condition,pretty common with holley carbs.
mike tkach is offline
Old 06-12-2013 | 01:01 AM
Had the same thing happen it my 28 Pantera with a 525SC. The high launch angle and pulling back on the throttle in the air would cause the bowls to overfill and flood the engine.
Griff is offline
Old 06-12-2013 | 06:17 AM
jeff32's Avatar
so, we all know what's the problem, but is there a fix to this? lower the float?
jeff32 is offline
Old 06-12-2013 | 07:35 AM
fuel injection
pstorti is offline
Old 06-12-2013 | 07:43 AM
vintage chromoly's Avatar
Make sure you have brass floats. The plastic/nylon ones are more "bouncy", so to speak.
vintage chromoly is offline
Old 06-12-2013 | 07:20 PM
Ted G's Avatar
Some of the old school racers would epoxy a small block of foam or plastic in the bowl under the float, this keeps it from bouncing so far down, some swear by it.
www.cbpba.com
Ted G is offline
Old 06-13-2013 | 05:36 AM
Mbam's Avatar
Offshoreonly Advertiser
Keep the fuel pressure right at 5 lbs, you might need a regulator. Higher pressure makes it harder for the float to keep the valve closed.
Holley also makse an offroad needle/seat
https://www.holley.com/6-513.asp
Mbam is offline
