525's Running Hot
Have a 2004 35 Fountain with 525's port motor is running way hot 195. Changed sea pump impeller and back flushed still running hot. Any thoughts on where to look next?
I had similar issue with a 502EFI closed cooling system. Took the end caps off the heat exchanger and found some gunk, cleared out the passages with a thin metal rod. All was good after that.
