24x7 aero.. can I remove the foam inside the hull
Boat is rock solid... thought about lowering the floor someday by the driver and passenger so drop down bolsters could be used.. its an aero.. yeah I know not a pantera or superboat but looks just like them and mine seems to be one of the better built ones.. no stress cracks.. original floor and stringers are rock solid.. boat is rigged right witj a 510ci bbc and bravo one and sweet paint job.. does 72mph so far.. nut I wanna update the interior next.. so I kinda wanna drop the floor and do bolsters.. but it has a ton of foam.. can I remove that stuff? Was it used for strength back in the day or floatation? Thanks for any help! If I could post pics I would.. also looking for a 24ft bunk trailer... thanks.. live in northern michigan area
so as far as you know.. the foam is only for gas tank placement? what is the purpose.. just to hold her tight? couldnt i use a hold down or strap of some type?.. would love to know more about these boats.. mine is an 85 aero.. prolly very similar to your 74.. which was a lancer.. im just assuming.. any info would be great.. is this boat decent enought to throw a little money into? if i could upload pics i would.. has a tyler crockett 509 or 510 in it with a ton of money in it.. with low hours.. has a nice really nice paint job too.. thats why i kinda wanna put some finishing touches on the interior.. an old pics of these boats layin around?
Have you talked to Tyler he might be able to give you more insight on your boat if it was his engine costumers boat.. This pick is one of his Lancers he built, nice use of cold roll steel for the trim...
All I can say is anybody who raced his boats built in the 80's & early 90's the race teams would reenforce them themselves or some had Tiger Fiberglass [Marysville Mi] go through the whole boat before they rigged them. Most boat builders @ that time used plywood for stringers, Klem use fur boards that's why the stingers are big. Drake found out on his boat [bad rigging & fur boards] how fast these hulls can rot out. If yours was rigged right you may have a good one. One way to tell, have it surveyed.
