525 help
Old 06-17-2013 | 01:17 PM
bill63's Avatar
Fast Priorty II Nor-Tech
Default 525 help
Down 500 rpm on star motor , sounds fine gages fine, idiles fine any ideas ? I can only get 4300 rpm top end . port 525 runs fine 4800 rpm
bill63 is offline
Old 06-17-2013 | 02:46 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Prop in good shape?
Have you checked all of the plug wires and spark plugs?
Sydwayz is offline
Old 06-17-2013 | 03:13 PM
I have no idea what your problem is but when you get it fixed you should be running closer to 5,300 on top end. Manual says 5,250; Rev limiter comes in at 5,400.
thirdchildhood is offline
Old 06-17-2013 | 03:19 PM
Knot 4 Me's Avatar
Sounds like it is down a cylinder but toss a scanner on it first. Boat is way over-propped.
Knot 4 Me is offline
Old 06-17-2013 | 03:49 PM
bill63's Avatar
Plug wires look good , going to get the motor scanned. The props on the boat are original from fountain but are in fair shape i just purchased new merc lab 32's for it hopefully that will help after I get the motor sorted out. I think I lost a cyclinder also.
bill63 is offline
Old 06-17-2013 | 03:54 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Given the boats you have listed, IMHO it would be a strong move to pick up a Rinda scanner. www.rinda.com
I just picked up the pigtails to play with my neighbor's 2013 40HP outboard as well.
You are going to drop $500 bucks, but it's worth it if you have to wait once or twice for 2 weeks to get a service appointment for a $50 sensor; even if under warranty.
Sydwayz is offline
Old 06-17-2013 | 04:03 PM
bill63's Avatar
Thanks i will look into that, these 525 are all new too me I think I like my verado's better !!!
bill63 is offline
Old 06-17-2013 | 04:22 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Share the cost with a couple of boating buddies and/or neighbors. http://www.rinda.com/marine/marine.htm#merctool
I prefer the scanner over the laptop software as I normally take the scanner with me everywhere, vs. a laptop. It's ridiculously easy to use, just like a code scanner for your ODBII port on your car, except better.
Sydwayz is offline
Old 06-18-2013 | 07:33 AM
If you can take a simple compression test, and make sure each hole is pretty close in pressure. Then run for codes.
92nsx is offline
