496 w/Whipple rebuild specs & clearances
I am helping a buddy rebuild his 496 with a whipple.
We pulled the motor down yesterday and it spun a rod bearing on #6. Not really sure why it spun because it didn't have many hours. It has eagle rods and diamond flat top pistons and standard crank. #6 piston slapped the head, so the piston will need replaced and hopefully the head isn't cracked. The piston is above the deck and it has Cometic head gaskets, I didn't measure the deck clearance but will upon assembly. The cylinder will probably clean up with a hone job because you can't feel any ridges, but it looks like a few metal scratchs going up and down.
It is all going to the machine shop today, but I need to tell them what clearances we want for the crank journals.Are the specs similar to the 502? I have rebuilt many BBC's but not a 496 w/blower. Looking for information on the following as the crank will need to be turned to 10 under; Oil pump Melling 10778c
Bearings, clevitte77?
Rod clearance! .0025?
Main clearance! .0025?
Crank end gap?
Piston deck height clearance .040?
Piston pin clearance .001 or .0015?
can probably get this from Diamond
Ring end gap top?
Ring end gap bottom?
Thanks for the help and advise!
Crank end gap?
Ring end gap top?
Everyone must be busy! We got the original specs from the builder the way it was, so it's pretty much the same as the 502.
Cylinder - .006
Mains - .003
Rods - .00275
rod side clearance .015
crank end play - .008 - .012
Cylinder - .006
Mains - .003
Rods - .00275
