454 carb thunderbolt IV... timing all over?? >
Old 06-17-2013 | 08:32 PM
Full Force's Avatar
Default 454 carb thunderbolt IV... timing all over??
I set my total advance at 34 degrees...... after around 4000 the timing jumps all over the place, I cannot remember if this has done it with multiple boxes since I have so many different issues to figure out....I have new coil, and new pick up, I am trying to find another ingnition module but I swear it did this with 2 different ones......
I am also thinking of ditching the merc ignition and going with something else....
What would be any other suggestions? this engine is very sluggish to go from 4500-5000 takes a minute catch up... does not feel as strong as port goes right to 5000
Full Force is offline
Old 06-18-2013 | 01:10 AM
The timing should not jump around at all. Sounds like a bad connection or ignition module. Swap them from side to side.
Griff is offline
Old 06-18-2013 | 04:08 AM
Full Force's Avatar
I run new small module on that engine, a old box on other one, I have a buddy with a few extras, I plan to grab one from him to use..... the connections are good as well as I ran new ground from battery to be sure...
Old 06-18-2013 | 06:12 AM
Biggus's Avatar
Is the rotor tight to the distributor shaft?
Biggus is offline
Old 06-18-2013 | 06:47 AM
Full Force's Avatar
I will check that didn't think about that
Old 06-19-2013 | 11:12 AM
I Agree. If that checks out I'd also take a peek at the distributor gear.
MILD THUNDER is offline
Old 06-19-2013 | 11:27 AM
Full Force's Avatar
I may just buy the msd distributor and drop it in...
