Go Back  Offshoreonly.com > Owners Forum > Sunsation
which yearl >
which yearl
which yearl
Old 06-24-2013 | 09:39 PM
Default which yearl
Looking to buy a sunsation 288. It'll be my first. Everything being the same HP,prop,gear ratio, etc...is there any difference in speed/performance between year models ex 2002-2005 etc. Thanks for any input.
dcm911 is offline
Old 06-25-2013 | 07:26 AM
Knot 4 Me's Avatar
2005 they went to a single step hull. Before that there is just a "Vortec" ventilator at the chine that resembles a step. So the 2005's and up will be the faster boats with all other things equal.
Knot 4 Me is offline
Old 06-25-2013 | 07:15 PM
OK. How much faster are we talkin. Can anyone give some speeds with hps and year models. I want to make sure if I find one with the looks I like I want be giving up too much on the speed side if its not the newer year models
dcm911 is offline
Old 06-25-2013 | 09:28 PM
I have a 2003 with the Vortec hull, 496 Mag, 24p Bravo1 with a full tank two adults i can hit 62 mph turning about 4400 rpm. Best i have ever seen is 63 low on fuel and turing 4500-4600 rpm. i'm told the HO motor on my hull its a 67mph boat. "CrownLPX" on here has i think an 05 with the step hull and the HO engine i have messaged him via OSO about upgrading to the HO motor and he mentioned he can hit 70-72. I saw his boat at Cumberland last weekend but did get to run with him as i missed my flight filling up at the gas dock.
bigredbaja is offline
Old 06-25-2013 | 10:52 PM
288KID saw 69-70 on gps with his 03 288 and 24p labbed....
AJ POWERPLAY is offline
Old 06-26-2013 | 04:09 AM
dcm911 email at [email protected] . My pm box is not working.
fasthawk6 is offline
Old 07-08-2013 | 11:34 PM
I'm running a 2004 288 Sunny with the 496 with a whipple and a set of CMI headers with dual ram ext steering and currently running a Hydromotive 5 blade 27Pitch and hitting 82 on dash Speedo and still can pull the kids on a tube. Sunsation 288 will give you the best of both worlds IMO.
HotForTeacher is offline
Old 07-09-2013 | 01:24 PM
Step hull 8.2 Mag HO 69-70 GPS every day full load.
rfgonzo is offline
Old 07-10-2013 | 10:30 AM
I have an '06 but same hull as the '05. Bounces between 71/72 running 4800-4900 in slight water conditions with a half tank and 3 people. Found with a little trim and running tabs neutral (not in the full up) adds a tick or two to the GPS. That was a phone with a GPS.
Sunny32SSR is offline
Old 08-06-2013 | 07:14 AM
Hey DY, I know where there is a good looking 06 within a couple of hours of you...Hint Hint
espeed is offline
