How easy to go dual hydraulic steering from single? >
Old 06-25-2013 | 04:59 PM
Default How easy to go dual hydraulic steering from single?
my 94 sunsation aggressor currently has a single ram hydraulic steering setup that runs to the helm. I am interested in going with duals if it isnt too much of a swap. Is it as easy as buying a second ram and running hoses?
cjmatt is offline
Old 06-25-2013 | 08:07 PM
Basically. If you already have full to the helm single ram all you would need to do is get a second ram,mounting hardware, wing plate (if you don't have one that is set up for duals) 2 Tee fittings for the one side and some lines. Not very complicated at all.
mickeymcclgn is offline
Old 06-25-2013 | 10:09 PM
Rookie's Avatar
Do you have a power steering pump on the engine? Or is the steering helm the actual pump?
Rookie is offline
Old 06-26-2013 | 06:04 AM
I have a power steering pump and the lines all run to the steering wheel. It's not the Brazil valve setup
cjmatt is offline
Old 06-27-2013 | 08:14 AM
Here is a pic of the steering setup on it. Do any of you happen to know who wouldve made this or where i can find the matching ram?
cjmatt is offline
Old 06-27-2013 | 10:32 AM
Rookie's Avatar
Looks like a hynautic ram that has been plated.
Rookie is offline
Old 10-24-2013 | 05:53 PM
do you have any pics of the inside of the boat, like the reservoir?
stlliberator is offline
Old 10-24-2013 | 07:22 PM
hynautic k5
johnnywhale is offline
Old 10-25-2013 | 06:24 AM
Dave M's Avatar
Veteran: Navy
Is your steering pretty solid now? I think a single ram system is adequate on a boat that size. I had a 24 Superboat, with a single ram, full system and the steering was great.
Dave M is offline
Old 10-25-2013 | 07:17 AM
http://www.go2marine.com/product/812...hrough-k9.html
Looks like the ram alone will run you $675
92nsx is offline
