496 stroker jetting questions >
Old 06-29-2013 | 08:26 AM
Default 496 stroker jetting questions
Have a 496 stroker getting finished in the machine shop right now after oil pump went on the first run of the season, dropping it in my baja hammer. Got a new Holley 750 and was looking for any info on jetting. Not that I'm not experienced with minor jetting, I'm more looking to see if the jetting is close for the first run or if anyone else has this set up n can give me a starting point. Also has Gil exhaust and edlebrock intake Mallory ignition. Current jetting is:
72 main jets
31 main squirt
80 secondary jet
28 secondary squirt
Any info is appreciated. Thanks!
Gfellas is offline
Old 06-29-2013 | 08:40 AM
i see you are a new member,welcome aboard,that jetting seems lean for a 496,i would start with 80 in front with a power valve and 90 in the rear with no power valve,better to be rich than lean on a marine engine.
mike tkach is offline
Old 06-29-2013 | 08:56 AM
Thanks! Yea I've checked the site out a bunch of times, figured might as well join and reach out to the tons of knowledge on here. A few people said that may be a little lean n to bump it up. Last thing I wanna do is fry it again with only a few months left of boating up here.
Gfellas is offline
