6 blade Herrings and Bravo XR's ? >
Old 07-01-2013 | 05:57 PM
Default 6 blade Herrings and Bravo XR's ?
Looking for some folks that have had success or experience with this setup. I have been breaking drives quite frequently and have been told that the low slip numbers achieved with these props are contributing to my issues. Has any one else had a similar experience. I am currently running them on a semi staggered 38 Fountain lightening with 575's and Teague chillers and a pulley reduction. I also have imco 2" shorties with 1:3.5 lowers turning 30p 6b herrings. Any input or experience with this setup would be greatly appreciated.
custom29scarab is offline
Old 07-01-2013 | 06:22 PM
Had a customer with a similar problem on a new 35 Fountain with 525's. Kept throwing blades on Herring 6 blades and breaking Bravos. We added 1" drive spacers and switched to Maximus props. Only lost 1-2 MPH, planed a lot better and so far hasn't broken anything. Those aggressive drive heights are really tough on Bravos.
Bob Lloyd
Full Throttle Marine
bobl is offline
Old 07-01-2013 | 07:20 PM
Bob,
Thanks that is great information and exactly the type of info that I am looking for. I have thrown two blades but they were both Bravo 1 4 blades that I lost a blade on. I could see how this would be related to the drive height as well. Thanks again for the info.
Old 07-01-2013 | 07:56 PM
No Bravo ever like being used as a surface drive, At high drive heights they Load/Unload too much (just going through regular wind chop) and the Torsion effect on those (relatively small) single vertical shaft drives is too much. Even compounded more with 6 blade props where blade area is high.
fastdonzi is offline
Old 07-02-2013 | 07:21 AM
PatriYacht's Avatar
Originally Posted by Back4More
Drive Guardian
PatriYacht is offline
Old 07-02-2013 | 08:09 PM
Isnt that just for low oil level?
Pokher Ace is offline
Old 07-02-2013 | 09:07 PM
[QUOTE=custom29scarab;3952161]Looking for some folks that have had success or experience with this setup. I have been breaking drives quite frequently and have been told that the low slip numbers achieved with these props are contributing to my issues. Has any one else had a similar experience. I am currently running them on a semi staggered 38 Fountain lightening with 575's and Teague chillers and a pulley reduction. I also have imco 2" shorties with 1:3.5 lowers turning 30p 6b herrings. Any input or experience with this setup would be greatly appreciated.[/
Wondering what kinda slip numbers you are running ? Thx
First Gun is offline
Old 07-02-2013 | 09:44 PM
Well best I can figure for slip is around 9-11% But I am no expert on the subject. Just run 5300rpm apx at around 100-103 depending on temp and humidty. Does this help you in any way?First Gun
Old 07-03-2013 | 11:13 AM
Help is on the way....
Back4More is offline
Old 07-03-2013 | 04:27 PM
Yes, tells me where the edge is most likely when running high x dim bravos thank you
