10 meter with factory outboard bracket >
Old 07-05-2013 | 09:26 PM
Default 10 meter with factory outboard bracket
Anyone have the hull weight of a standard 10 meter fountain. I just bought a 1986 fountain 10 meter that was rigged from the factory with an outboard bracket and they must not be too common. I will be installing twin 275 Verados and was wondering if anyone has a similar setup or could point me in the direction of some old advertisements.
Thanks, Jason
Jaizzen is offline
Old 07-08-2013 | 07:57 PM
Any help will be appreciated.
Jaizzen is offline
Old 07-08-2013 | 09:42 PM
Wish I could help. But those are rare. You might want to figure out who made the bracket and see if they have any info on where to mount the engines. I would start with the propshaft flush with the bottom of the hull. Hope someone here with first hand experience could chime in here.
turbo rr is offline
Old 07-08-2013 | 09:54 PM
Thanks so much for the reply. Fountain made and installed the bracket. As I understand it, they made 12 or 14 hulls like this one or so I've been told. I've built a potter sea craft, and an old Cary and I from experience, this was all factory work.
Is there an archive for fountain boats out there? I am looking for information or photos of the original hull. I can't even find an accurate hull weight on the 10 meter hull.
Thanks again for the reply, jason
Jaizzen is offline
Old 07-09-2013 | 02:40 AM
If it is a tubular bracket it was most likely made by GIL. They are no longer made. If it is one piece it could be a Stainless Marine unit and they may be able to assist you with set-up.
sonicss42 is offline
Old 07-09-2013 | 03:22 PM
If its one piece it could be Armstrong also. They are still in business.
Looks like they made 2!!
http://www.offshoreonly.com/forums/g...outboards.html
turbo rr is offline
Old 07-13-2013 | 04:06 PM
kcsteve124's Avatar
Default 10 Meter Outboard
[ATTACH=CONFIG]504303[/ATTACH][ATTACH=CONFIG]504304[/ATTACH][ATTACH=CONFIG]504305[/ATTACH] A review I read on the first 10 meter sport fish said Gil
Attached Thumbnails 10 meter with factory outboard bracket-fountain-10-meter-outboard.jpg   10 meter with factory outboard bracket-fountain-10-meter-outboard.jpg   10 meter with factory outboard bracket-fountain-10-meter-outboard.jpg
kcsteve124 is offline
Old 07-13-2013 | 04:22 PM
This is exactly what I was looking for..... That's my boat.
Can't thank you enough!
Jaizzen is offline
Old 07-18-2013 | 07:09 PM
If that hull weight is anywhere close to correct..... It should absolutely fly with those 275 verados
Jaizzen is offline
Old 07-18-2013 | 08:25 PM
Cool, post pics of the boat and project! I cant believe that weight is anywher close to 3000 lbs.
Pete280 is offline
