Trying to identify my prop ...hydromotive? >
Old 07-08-2013 | 05:56 PM
Default Trying to identify my prop ...hydromotive?
Numbers stamped neer the splines are: HC-CL23L-O-IV
Four blade
Measures just shy of 15.5" from tip to tip
I'm thinking this is a hydromotive intimidator quad IV
15.5x23p
If you need more info let me know ill try and post a pic
tdpb2008 is offline
Old 07-08-2013 | 06:10 PM
bbladesprops's Avatar
Offshoreonly Advertiser
You are correct. That is what you have. LH rotation.
Brett
[email protected]
bbladesprops is offline
Old 07-08-2013 | 06:52 PM
Ok great
Ok I have a 27 fountain with the 502 mpi and I guess they come with the hydro from the factory and out of the factory the sheet claimed 68mph @5000rpm
I was getting 55mph gps speed out of the hydro so I took it off and bought a bravo 1 labbed prop off here and now I am around 60mph @ 46-4700 rpm with the bravo
My question is what prop would I be better off with for speed?
I'd like to be around 68-70 where most 27 fountains are running
tdpb2008 is offline
Old 07-08-2013 | 07:11 PM
Both props can work well. Our experience has shown a properly Labbed Bravo 1 to out perform the Q4. This isn't 100% of the time but in the majority of the cases.
Was the 23 Hydro Q4 on the limiter?
What pitch is the Bravo 1 you bought and where was it Labbed? I assume it is a 24 pitch. In order to run 68 mph with a Bravo 1 24P, you would need to turn it 5100 at 9% slip. That looks to be a tough option since you are only at 4650 now with 12.5% slip.
Let us know and we can help to get you closer to your goal.
Brett
[email protected]
Old 07-08-2013 | 07:39 PM
The hydro was at 47-4800 if I remember ...that was in 60 degree weather last season
tdpb2008 is offline
Old 07-08-2013 | 07:41 PM
The bravo is a 24p
The hydro is a 23p that came on the boat from the factory and they claimed 68 mph WOT
tdpb2008 is offline
Old 07-08-2013 | 07:43 PM
I have your testing form and going to do some testing this weekend on both props
tdpb2008 is offline
Old 07-08-2013 | 09:44 PM
Perfect,
Let's get some back to back accurate numbers and go from there.
Brett
PS, if either of these props have been touched, even repaired, I need to know. Also, LH props are common on your hull due to listing....................
[email protected]
Old 07-08-2013 | 10:05 PM
The bravo, I was told it was "labbed" but not positive by who
The hydro looks like it has been touched
I could send you some pictures if you want also
tdpb2008 is offline
Old 07-09-2013 | 11:27 AM
Yes,
Email the photos to [email protected]
See if there are any stampings on the barrel or inner hub of the propeller as well.
Brett
[email protected]
