X- Dimension on your boat??
Registered User
I know we have covered this before, but I would like to know what everyone else is running and any performance issues,
X-Dim ?
Speed ?
Planning off ?
WILL
X-Dim ?
Speed ?
Planning off ?
WILL
Official OSO boat whore
I'm not real sure. The factory set it at 19.25". I raised it one inch above that when I put the box on. I'm also using a 2" shortie. As it's set up, the prop shaft should be 1" above the bottom. This is on a 26' single engine cat with a notched transom and a 12" set back box. Guess if you did the math I'd have a x of 21.25"+2" for 23.25".
