X dimension? >
X dimension?
X dimension?
Old 08-24-2004 | 03:14 PM
phughes69's Avatar
Default X dimension?
I finally remembered to measure the bottom of my boat (38 KV scarab with SSM #2) I measured 6 1/2 inches vertically between the bottom and the centerline of the prop shaft. The props are 15x23 3 blades. How does this translate into a supposed X dimension. Did I measure it wrong? How am I supposed to measure it?
phughes69 is offline
Old 08-25-2004 | 06:58 AM
J-Bonz's Avatar
Default Re: X dimension?
Some one please correct me if I'm wrong but, X-dimension is the vertical mesurment from the U-joint shaft to the bottom of the hull.
J-Bonz is offline
Old 08-25-2004 | 07:04 AM
You Are Correct Bottom To The Centerline Of The Shaft.
z.zuperboat is offline
Old 08-25-2004 | 08:07 AM
Yes, J-Bonz, That is "X" dimension. phuges is referring to running depth and that sounds a little deep to me. Were the lowers changed over from TRS units (which were shorter than the speedmasters) some time after the original factory set-up? --- JP
jpclear is offline
Old 08-25-2004 | 08:55 AM
What he said. The IIs are taller than a TRS. The shaft cenetrline should only be a couple inches below the bottom. I've run TRSs higher than that on a staggered 38.
Good news is that if you switch to TRS lowers, you'll probably go faster. Or raise the IIs a few inches and it should really fly.
Gary
Gary Anderson is offline
Old 08-25-2004 | 03:53 PM
Comanche3Six's Avatar
X dimension is measured at the transom from the keel to crankshaft centerline.
Comanche3Six is offline
Old 09-02-2004 | 04:26 PM
Speaking of X-
Does anyone happen to know the X-dim for a 28' Sleekcraft Enforcer- Have a virgin transon and no clue. Sleekcraft don't annswer the phone.
MLEVEN63 is offline
Black Wishbone
Sutphen
4
03-11-2008 07:02 PM
40FlatDeck
Skater
10
01-11-2007 10:28 PM
375stinger
Cigarette
0
11-10-2004 04:56 PM
Bajaforce
Baja
2
03-05-2003 08:09 AM
sambryce
5
03-04-2002 05:27 PM
