Go Back  Offshoreonly.com > General Discussion > Boating Safety
Fire Extinguisher expiration >
Old 07-28-2013 | 10:23 AM
Default Fire Extinguisher expiration
I was out yesterday got stopped to do a safety inspection (presumably after the DNR constitution burning party). Apparently, according to the DNR one of my fire extinguishers is expired. I have never heard of this so I looked it up and under Utah law a disposable fire extinguisher expires 12 years from its manufacture. What I do not understand is how one would know if it is disposable? There is a sticker says made in 1993, coast guard approved etc, but does not say disposable. anyone know?
jmmcintyre is offline
Old 07-28-2013 | 10:46 AM
If anything like PWC extinguishers the dates are on the bottom of the tank. hope that helps!
abones is offline
Old 07-29-2013 | 07:13 PM
dates are stamped on current extinguishers, but gauge reading trigger release need to be intact. the main thing that will screw you should you need to use it, is powder compacted. take extinguisher and on its side, rock it, can you feel powder flowing. if not turn upside down and shake, if powder does not break loose, it is bad extinguisher. when discharged get about 15 seconds of gas, no powder(agent). the gas is normally nitrogen=dry gas, rock test is best determination of condition of ext.. I have asked everybody that gets stopped by DNR, none have ever had them do rock test or can explain it to them, its regular maintenance for ext. local jag's consider installed(engine compartment) a portable ext., all they want is to write tickets, no education, hell they don't understand it actually themselves. I did boat inspections for first 10yrs in the coast guard, my job was to inform boaters for their safety, congress moved boating safety $ away from us to state DNR's, and they get power squadron/abyc/coast guard auxillary to do their training. sorry for rant.
keith2500hd is offline
Old 07-29-2013 | 09:00 PM
I looked up he model number and indeed they do expire 12 years from manufacture. I guess the DNR gal was correct. Should be good now with a new one. Definitely something I want to work if I need it. Interestingly the powder inside I can feel still moves and gauge still in green.
Old 07-31-2013 | 06:43 PM
Formulabill's Avatar
Buy new ones and keep the old ones for spares. You can never have enough fire protection in the case of an emergency. If you have them mounted with a push -pull pin check the device to make sure you can get the extinguisher out. Had a big engine fire and the pin would not release. Luckily the auto system came on and slowed the fire down and a boater came by and gave his extinguisher to finish the job.
Formulabill is online now
Old 07-31-2013 | 10:01 PM
I had no idea they expired, I always thought if the guage was green you were good too go. I will have to check mine .
happy hours is offline
Old 07-31-2013 | 10:23 PM
I usw the old ones to train my kids how to fire off an extinquisher!
Port Monster is offline
Old 08-13-2013 | 04:16 AM
same here mate, i have will check mine too.
paulsnider11 is offline
Old 08-17-2013 | 09:27 AM
Disposable extinguishers should have a plastic head on them. Ones with metal heads can be serviced/hydrostatic test and refilled and used for 12 more years.
fordf350 is offline
Old 09-05-2014 | 06:53 AM
You have to service extinguisher every year. or remember when you bought it. And from that date it's good for one year to avoid red flags from inspector.
chardricketts is offline
