496 Stroker Build Help which Cam?
I am buikding a set of 496 Strokers, but dont know what is the best Roller Cam for this setup.
1- Gen 6 Blocks 0.60 Over, Roller Block
2- 4340 4,250 Crank
3- H beam Rods 6.385
4- Icon Pistons IC9951
5- 088 Heads
6- Holley Carburater
Whats the best Roller Cam for this Combo?
Any help will be greatly appreciated.
Frank
2- 4340 4,250 Crank
5- 088 Heads
Frank
You did not post what exhaust you are running. That would be the most important part.
I have built several 496 strokers with Bob cams. They run great!
Let's assume these specs...
9.5 compression, EMI Revolution Marine exhaust (comes out under the water), heavy boat, dual plane intake. Current cam is Crane Roller Retrofit --> .553/.556 lift, duration @.050 214/222 --> What would you guess on Horse Power? Do you think this cam is a good match, or could I stand to go bigger?
