Hydraulic hatch accuators
Crazy Energy
any ideas? Here's the deal
I have these hydraulic rams I plan to use to open and close my two hatches on the cat project. I also planned to use a trim pump to power these rams. The problem is the trim pump tank does not have enough capacity to fully open these long cylinders. Do they make a larger tank to fit the trim pumps (probably not) should I try to modify a tank to fit the trim pump that has enough capacity?
These are the tanks I have now.
[ATTACH=CONFIG]505691[/ATTACH]
cylinders
[ATTACH=CONFIG]505689[/ATTACH]
cylinders
