Shore power problem on a 35 Outlaw >
Old 08-10-2013 | 08:23 PM
Default Shore power problem on a 35 Outlaw
Im not getting power to the breaker panel on my 35 outlaw. Does anyone know of a fuse or breaker between the power inlet on the transom and the AC panel in the cabin? Thanks for the help.
Fordman08 is offline
Old 08-10-2013 | 09:23 PM
neva satisfied's Avatar
It's probably a bad ground. Take the panel out, loosen all the grounds and retighten them.
neva satisfied is offline
Old 08-11-2013 | 05:12 AM
Pull the plug out of the side of the boat. Sometimes too many wires can get tywrapped to them and when hanging and hitting waves it will pull the wires out of the back. If they look good you can check he continuity while its out.
Katanna is offline
Old 08-11-2013 | 07:35 AM
Thanks for the ideas, I will check both today and reply
Old 08-11-2013 | 03:57 PM
Pulled the transom connector, everything is good.check for voltage to the wires and was ok. Pulled the ac panel again, not getting current to panel. Is the power inverter in the circuit before the breaker panel? Thanks again
Old 08-11-2013 | 08:29 PM
Check for rat droppings? Those lake rats will chew right through wiring.
[IMG][/IMG]
CumberlandDayton is offline
Old 08-18-2013 | 06:24 PM
I finally got it fixed. There is a breaker on the port side under the rear seat hidden behind a battery. You can not see it, I followed the wiring to it. It just needed flipped back on. Thanks everyone for the feedback.
