Go Back  Offshoreonly.com > Owners Forum > Donzi
38 zx Prop Slip >
38 zx Prop Slip
38 zx Prop Slip
Old 08-11-2013 | 08:39 PM
Default 38 zx Prop Slip
Looking to see what other owners are seeing for prop slip with a 38 zx. RPM/Gear Ratio/GPS Speed/Prop Pitch?
Wilks is offline
Old 08-14-2013 | 10:23 AM
glassdave's Avatar
Neno the mind boggler
I see around 13 or 14 percent
2000 38 ZX
525SC's
28 inch labbed B1's
best of 80 mph at 5200 rpm when new
w/same non labbed 77 mph at 5200 rpm (16% slip)
08 OPA High Points Champion
glassdave is offline
Old 08-14-2013 | 08:26 PM
do you have standoff boxes?
What drive trim is optimum for you?
I am seeing a lot higher slip than that.
Wilks is offline
Old 08-15-2013 | 11:23 PM
glassdave's Avatar
no boxes its a standard ZX. not sure where its trimmed I run the boat by feel but they are out a bit. I usually bring the boat up on plane with them level, and as the boat comes up in speed I will trim them out and find a sweet spot.
whats your setup?
Old 08-16-2013 | 03:09 PM
loaded 2001 daytona with 225hr 575sci's. Stellings boxes. Had Bravo shop upgrade the XR's.
I do the same thing when coming up on plane. around 5 on drive trim seems to be the best. lower decreases speed and rpm. higher increases rpm but no speed change. Leave the tabs up to level which is around 1.
Props are lab B1 32p.
Wilks is offline
Old 08-17-2013 | 11:12 PM
Have you measured your drive tow? If so what is it?
whats your setup?
Wilks is offline
