Cleaning Suggestions Windshield on Cat >
Old 08-19-2013 | 10:54 AM
Default Cleaning Suggestions Windshield on Cat
Hey Guys, Recently put a windshield on my 28' Skater. Use the boat in salt water and the spray from the tunnel blows up the deck sometimes and I wanted to know if anyone has found a good way to keep it clear as possible. Was thinking rain X?
Any help would be appreciated!
Double Rigged is offline
Old 08-19-2013 | 11:00 AM
Sydwayz's Avatar
Forum Regulator
I would not try Rain-ex.
This is what many folks use on canopies and the like: http://www.plexusplasticcleaner.com/about.html
Sydwayz is offline
Old 08-19-2013 | 12:23 PM
SS930's Avatar
Brian is right, I wouldn't use rain-x on it without some testing... the solvent might cloud the polycarb. Some guys use wax on polycarb, but I'd suggest testing it in a small area or on a test panel first.
Regardless, salt will still build up and it will also scratch the surface if you try to wipe it off dry. A washer system would really help, if you don't mind the spray from it. I believe it was Chris at Ocean Performance that was telling me they used Salt-away in a spray bottle with excellent results.
SS930 is offline
Old 08-19-2013 | 12:33 PM
offshoredrillin's Avatar
Don't use plexus, it has petroleum distillates in it and will eventually turn it yellow. We used to use it on PPF until I found out the MSDS on it. use a product called brillianize... specifically made for laminates, so good you can use it on big screen TV's.. I stock it if you need some i can get it to you.
offshoredrillin is offline
Old 08-19-2013 | 12:40 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Aeromarine has their own cleaner called "Crystal Clear"
Call Carmen. ... 909-350-3543
Arneson Surface Drives www.arneson-industries.com
Rik is offline
