Help, Pump Out Head Question
Charter Member #34
Hello Baja brothers. I really need your help.
The wife and I stayed out on the 36 Outlaw Friday to Sunday and the holding tank on the vacu-flush pump out head is FULL!!!!!
The last flush this morning and it came out the air vent on the side. I know this is not good, probably messed up the filter.
The problem is this. Friday I tried to suck out the tank and got nothing. Checked all my manuals again, talked to a few buddies, looked for a valve or switch (dealer said there were none), tried different marina's, no luck, not a thing will come out.
We have not put anything in the toilet that has not been eaten first, no paper, no nothing, period.
What is going on here? We are going to the coast this Thursday and the dealer won't be open till Tuesday, so I'm hoping you guys can give me some advise. I got to get this thing emptied.
Thanks in advance, Mark
Charter Member #34
Problem Solved, you won't believe this!!!!!!!!!!!!!!!
One other problem I had today was that the fresh water holding tank run dry. I went to fill it and to my surprise it only held about a gallon of water and was overflowing. Tried the water in the sink and the transom shower and NO WATER?
You are not going to believe this ****! Baja put the fitting that says fresh water on the toilet pump out and the toilet pump out is labled fresh water. The wife and I have been outside in the dark for the last two hours and have just figured it out.
I cannot believe this? WASTE = **** right????????????
Fresh water = Clean water for sink and shower right????????
They have everything labled backwards.
I filled up the waste inlet, held at least 20 gallons and we got good clean water. I put the hose in the fitting labled fresh water and we got **** coming out the vent.
This really sucks!
Thanks Mark
This really sucks!
Thanks Mark
UNBELIEVABLE!
