Need prop size help f26 dcb >
Old 08-20-2013 | 08:33 PM
Default Need prop size help f26 dcb
I have a f26 dcb with 854hp at 5500 rpm with xr drive 1.36 gears we've tried a 30 4blade an 32 4blade labbed bravo 1s can't get any good numbers out of the boat an wont spin any hire. Should I go to a 5 blade what size an pitch. Any help would b great thanks guys
RVR2SND is offline
Old 08-26-2013 | 01:03 PM
Do you have a rev limiter at 5500 rpm? It seems there should be an rpm difference between the 30 and 32's you ran. What speed and specific rpm are you getting with the 30 & 32's? We can look at the slip numbers to see what is going on. This will help determine whether a 5 blade will work better. Usually they do.
hec2buck is offline
Old 08-27-2013 | 11:46 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Speed numbers are required at the 5500 rpm level with both props to make a good assessment. The props should run similar rpm at WOT since the 32 I Labbed
However, 5 blades don't "usually" run better. That is a immature statement till we know more. Depending on the efficiency of the current props, who Labbed the 32 and to what recipe, it is impossible to say a 5 blade will be better on a f26.
Get some more info and we can better discuss the set up.
Brett
[email protected]
bbladesprops is offline
Old 09-04-2013 | 04:01 AM
Brett
Thanks guys for responding headn out this coming weekend. Going to plug in the computer to make sure that the rev limiter isn't set at 5500. Also the speed was 97 mph at 5500 with the 32. Thanks again
RVR2SND is offline
Old 09-04-2013 | 06:03 PM
19% slip is a little high.
We'll wait to hear back after more testing.
Brett
[email protected]
