Camshaft Help!!!!!!!!
Old 08-22-2013 | 01:10 PM
Default Camshaft Help!!!!!!!!
Bought a used 454 Gen VI roller cam, but cant reference any number.
Says on rear of Camshaft 2296 7031 and on side WB 02197 53.
Any help would be appreciated.
Frank
automobili_v12 is offline
Old 08-29-2013 | 07:32 PM
mcollinstn's Avatar
Why would you buy a cam of unknown grind?
You can always spin it on a couple of vee blocks with a degree wheel on it and a dial indicator. With that setup you can map the duration, lobe center, and lift of the cam. Sounds like that's going to be your only hope unless somebody recognizes those numbers (I don't).
MC
mcollinstn is offline
Old 08-29-2013 | 09:20 PM
Sounds like a typical Swap Meet deal. "What does it fit; Well what ya got"!
Cory H is offline
Old 08-29-2013 | 10:09 PM
Use it for a paper weight. Not worth the risk to use an unknown component.
sonicss42 is online now
Old 08-30-2013 | 04:20 AM
vintage chromoly's Avatar
Find someone with a cam doctor and see what you have.
vintage chromoly is offline
Old 08-31-2013 | 01:07 AM
Check with your local machine shop as Vintage Chromoly said if they have a cam doctor they can tell you what you have or don't have. If that doesn't work some cam manufactures will check them if you send it to them. Make sure if you go this route you pack it very good I sent one to my cam guy it arrived to them broken, UPS would not cover it even though it was insured. I hate to say it but if you got a good deal on it .....there is a reason . Good Luck
jamie 10017 is offline
Old 08-31-2013 | 07:43 AM
Default used cams
Buying a used cam is risky business.
And the effort to install.
Then to set the valves properly.
After all that work what happens if the cam shaft is not hardened properly.
Its a lot of effort for an unknown.
Your much better off buying a new cam. matching lifters, and valve springs and now you know where you are.
Good luck anyway sometimes you get lucky, but your time is worth money.Let us know if you have been successful or not.
Big Boys Toys is offline
