Help! Gasket material question >
Old 08-25-2013 | 01:11 PM
Default Help! Gasket material question
I have a gasket leaking on my gas tank sender. After looking around at all the local performance stores I could not find any sheet material that would work in stock. I eventually Got some from CP Performance in a sheet material. Its a Cellulose/Nitrile gasket. Is there anyone with known knowledge of this material that knows if it is fuel resistant? I have not found a for sure answer on the net and Jim at CP was not totally sure but said it should work. Also I am having trouble finding fuel resistant gasket dressing like hylomar. I cant find the permatex anywhere in stock. I need some help!
Aasved is offline
Old 08-26-2013 | 07:27 PM
I would use Mercury Perfect Seal for a gasket dressing....
mallatt442 is offline
Old 08-26-2013 | 11:04 PM
west marine use to sell just the gasket for the sending unit for a few bucks..should be made out of a cork looking material..here is another place..http://www.shock-price.com/result/s_...it-gasket.html
FIXX is offline
Old 08-28-2013 | 10:29 AM
I used the thick rubber one...cheap
ezstriper is offline
Old 08-28-2013 | 10:36 AM
EPDM would be my choice
kvogt is offline
