are nada weigts correct?
hi. looking at old supes-panteras etc...nadaguides lists 24 panteras at 3800 lbs. 24 supes at 1800 lbs. you take out 1100 lbs of engine-drive, and there is only 700 lbs of hull? is thhis anywhere near correct?
24 SB , no power should be 2300-2500 . What did he tell you ? Should have been Coen himself and he would know . You can also have a lighter one built wood free but that will cost couple grand more .
Pantera is the only other co I know that will build 24/7 still and theirs is a couple hundred ponds heavier due to all wood construction and thicker layup .
