eaton 11 drive want to change >
Old 08-31-2013 | 10:43 AM
Default eaton 11 drive want to change
is there a drive that will work without redoing transom?
cig20 is offline
Old 08-31-2013 | 11:31 AM
which drive??? and what do you have for power???
FIXX is offline
Old 08-31-2013 | 12:39 PM
302 ford eaton 2 on a 1970 donzi
cig20 is offline
Old 08-31-2013 | 05:35 PM
So its a eaton II drive and you want to updat the boat with a newer style drive..with you having a ford engine you dont have alot of choices..volvo and volvo are the current ones that have ford bellhousings for your ford engine..unless you wanted to update the whole thing and put a chevy combo in the boat..
FIXX is offline
Old 08-31-2013 | 09:36 PM
will Volvo fit in same hole in transom as the eaton ll or will transom have to be filled and recut
cig20 is offline
Old 08-31-2013 | 10:19 PM
is yours the one that does a 180* swing for trailering? is so then you may be able to get away with a volvo housing because they are big..but if it were me i woulf gomercruiser and convert to chevy..
FIXX is offline
