Tantrum motor !
Finally got the motor back for the tantrum . going to finish reassembly this week and try to have it installed by next weekend . [ATTACH=CONFIG]507270[/ATTACH][ATTACH=CONFIG]507271[/ATTACH][ATTACH=CONFIG]507272[/ATTACH]
had that happen numerous times,,if its just the last 3/4" that wont go in most likely its the 2 larger o rings on the shaft binding when they hit the gimbal bearing,,
you can verify this by removing the o rings and try installing the out drive I bet it will slide all the way in,,,I just start a nut on each side and slowly tighten evenly and it goes right in..
if it was the alignment you would not be able to push the outdrive that far in..
the prop does not turn because your in gear
