HP500 engine and 502 parts lot
I have the following for sale as a lot. I am hopefully going to superchared 502's One money takes all.
1 complete hp500 complete from carb to pan. No accessories. It is .034 over making it a 509ci and has Keith black forged high compression pistons (IC807 0.034). The heads were brand new gm 088 castings with the larger valves installed. It has the standard hp500 roller cam, comp hydraulic roller lifters, and 1.7 roller rockers. Engine has approx 30 hours on it since being built. No exhaust.
1 hp500 502 short block that has a busted piston and two broken rods. Two cylinders appear to have damage but may be able to be sleeved? Crank may be junk or may be able to be turned down. It has a crane 169611 hp500 hydraulic roller cam. I have the Intake and carb that came off this engine as well.
1 set of used Crane 900-16 roller lifters
1 set of low hour PBM link bar roller lifters (PBMRL931)
1 low hour 169611 hp500 hydraulic roller cam
1 set of Icon (keith black) 10.5-1 pistons .034 overbore 3-4 of these are flawles and a couple have some knicks in the top
2 sets of gm 088 heads, both sets may need some welding, 2 heads worse than the others. All will need new exhaust valves and spring sets. All have screw in studs with guide plates.
I set of BBC hp500 roller rockers 1.7 ratio
1 502 melling oil pump new in the box
$7000 takes all located in lafayette Indiana
Pistons are for a 502. Id like to keep everything together for now unless you want to make an offer I can't refuse. $6500 and you can have everything. The one engine is still in my boat if you want to hear it run.
