KAAMA Surface drive value >
Old 09-10-2013 | 08:24 PM
Default KAAMA Surface drive value
hey guys, I have a pair of surface drives from a 302 Formula. Havent been used in awhile. need paint, and im sure more. I have steering, props and such. one trans but its in rough shape (sat in the boat with water in it) What are these things worth?
krisx125 is offline
Old 09-11-2013 | 08:25 AM
No one??
krisx125 is offline
Old 09-12-2013 | 02:48 AM
Clean out your inbox I tryed sending a PM I would like some more info.
Greatlaker is offline
Old 09-12-2013 | 04:37 PM
Do you know the ratio of the gears? Have you got any of the steering cylinders or brackets.
CDShack is offline
Old 09-18-2013 | 10:51 AM
Steering is in the pic. No idea on gear ratio. How do you tell?
krisx125 is offline
Old 09-18-2013 | 03:21 PM
turn the input shaft 1 revolution. Watch the prop shaft and see if it turns one revolution they are 1;1 gear ratio. if the prop shaft turns to about 330 degrees they are 8% either over or under, as you can switch the 8% to over drive or under drive. Much cheaper than buying props.
BOATMAN302 is offline
Old 09-18-2013 | 03:24 PM
The drive which is standing up has a tag on the left side. It has the gear ratio on the tag, which is the way it was built, unless they were changed.
Old 09-19-2013 | 05:04 PM
Definitive way to tell the exact gearset is the tag, affixed to the drive just under the trim mounts on the left side of the drive. Generally in percentages. I have a "+13%" and a "0%" (1 to 1) set. Without that, the spin and count method works close enough. The cylinders are trim cylinders, not steering. One trim cylinder is missing the drive mount plate which ties the steering cylinder AND trim cylinder to one drive. (they made dual and single cylinder steering--the other bracket indicates this was originally single) One cylinder has the bracket (3 holes) that mounts to the top of the drive. I don't see any steering at all except the tie bar. Missing one cavitation plate. Looks to be first series drives. They changed around 1986-7(?) to what called a "teardrop" gimbel which is tall and the trim cylinders attach to it. Before stopping production, the last series was what was known as an "investment" drive, relating to the casting process. Thinner skegs and stantions, more hydrodynamic shape. very rare and bring the most money.
Most of my props are set up for the "+13%" gearset. If that's what you have, I'd like to talk to you about them.
CDShack is offline
Old 09-20-2013 | 01:23 PM
looks like one is a long shaft (desirable) with a spacer, the other one is short shaft. let me know what you find out on gear ratios. I've passed your info on here to a buddy who runs Kaamas as well.
CDShack is offline
Old 09-23-2013 | 05:51 AM
kris. your inbox is full. wanted to ask about the pantera.
dereknkathy is offline
