Someone please explain what hydraulic steering I will need..add on..or full >
Old 09-13-2013 | 05:06 PM
Default Someone please explain what hydraulic steering I will need..add on..or full
I want to add hydraulic steering onto my 88 Baja 24fter..The boat runs 70 wide open, but I don't run it that hard all the time. But running at LOTO, with the tabs down to fight through all the chop I get a lot of bow steer. I just replaced the gimbal, and steering pin a couple of years ago, but it still has a lot of side to side play in the outdrive. I am going to be doing some motor work this winter, so I want to be around 75-78 mph when finished. Should I just do a "add-on" kit, or should I go a full system? How does a add on system work?
stlliberator is offline
Old 09-13-2013 | 06:02 PM
GPM
Add on will still wander, full hydraulic is the best if you can afford it.
GPM is offline
Old 09-13-2013 | 06:14 PM
Full is best.
Crude Intentions is offline
Old 09-13-2013 | 07:15 PM
Thumbs up Imco
I just did a full IMCO system to my 23' boat this year and it is night and day better than it was. I actually feel in control of the boat at all times and that was not the way it was before I replaced my tiller arm setup.
toyo321 is offline
Old 09-14-2013 | 03:50 PM
articfriends's Avatar
That's the truth, my boat was not much better with just dual ram add on, went full and its rock solid, Smitty
articfriends is offline
Old 09-15-2013 | 01:13 AM
I had add on on my 28 Pantera. It was nice for the safety factor, but nothing like full hyd. It still pulled to side like normal steering but was just tighter.
Griff is offline
Old 09-16-2013 | 12:08 AM
i went from full cable steering on my htm ss24 to full hyd it was like night and day. at 100mph it was like driving a 1984 suburban compared to a 911 Porsche after. there was so much slack in the steering it was actually scary to drive the boat even at low speed. if you can go full hyd the steering precision is incredible! no add on you still have cables involved, you wont regret the full hyd system. btw this is the second boat I have done this to with equally great results.
La/stryker is offline
Old 09-16-2013 | 03:26 AM
c_deezy's Avatar
Full hydro is worth every penny. I haven't driven a single with full hydro, only a twin but it was night and day difference, like has been mentioned. Went from barely controllable to not even needing a hand on the wheel.
c_deezy is offline
Old 09-16-2013 | 02:43 PM
Dave M's Avatar
Veteran: Navy
Yup, full is the way to go. You can probably get by with a single ram system on a boat that size if you want to save some coin.
Dave M is offline
Old 09-16-2013 | 03:33 PM
I have an add on cylinder and it's not enough, I will be going to full hydraulic this winter. The boat gets to squirrelly after 70 even with the external cylinder.
ThisIsLivin is offline
