prochargers and boost >
Old 09-15-2013 | 12:41 PM
Default prochargers and boost
you guys with prochargers,what size engine do you have,which procharger unit are you running and how much boost are you making?im mainly wanting responses from pump gas users.
mike tkach is offline
Old 09-15-2013 | 01:30 PM
502mag mpi
M-3 Procharger
5 1/2psi with 4 1/2 pulley and 30 pitch prop.
sppbler222 is offline
Old 09-15-2013 | 02:33 PM
CNC's Avatar
CNC
572
M-4 Procharger
13 lbs on 93
MEFI
CNC is offline
Old 09-15-2013 | 06:04 PM
what horsepower does your 572 make
tcnomoney is offline
Old 09-15-2013 | 06:05 PM
509 MPI, M1, 5-6lbs
Griswald is offline
Old 09-15-2013 | 06:51 PM
articfriends's Avatar
540 w m-3 sc, with 3.85 pulley I dynoed at 12-13 lbs of boost on 92/93 octane pump gas (1057 hp), run 14 lbs with 20% race gas with 3.70 pulley (1115 hp). With these smaller pulleys it makes boost EARLY and FAST too if you lean on it anywhere above 3000-3200. It also made about 10-11 psi with 4.00 pulley and just over 1000 hp, Smitty
articfriends is offline
Old 09-15-2013 | 07:02 PM
smitty,what would you concider maximum boost with 93 pump gas?
Old 09-15-2013 | 07:12 PM
IF a Prochargerd marine motor has EFI, afr's verified/tuned on water at wot, aluminum heads and compression close to or around 8-1 along with 75-80 MAX degree lake water for innercooler 12-13 lbs is easily reliable, I have ran that kinda boost for quite a while and haven't hurt a motor yet, Smitty
Old 09-15-2013 | 07:32 PM
12 or 13 is what i was thinking,that is what i run with my 8.3L whippled 588s.
Old 09-15-2013 | 08:09 PM
Turbojack's Avatar
Had, 540, M4, 10 lbs, fast efi, Boat was sold from person I sold it to. He or I did not have any motor problems.
Turbojack is offline
