Adding Cup to props does  it really work??? >
Old 09-15-2013 | 01:45 PM
Question Adding Cup to props does it really work???
I might be doing something wrong but Mild Thunder recommended adding cup for better planning.. it`s really not working..maybe try some better tape? Its all I had on hand...
any help is appreciated.
ICDEDPPL is offline
Old 09-15-2013 | 01:50 PM
97FASTech's Avatar
Veteran: Army
I see the problem. You have the cup turning out, it should be an inward rotation. lol
97FASTech is offline
Old 09-15-2013 | 01:53 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I concur; albeit you may want to distributive your cup a little more than 20%.
Sydwayz is offline
Old 09-15-2013 | 01:54 PM
Crude Intentions is offline
Old 09-15-2013 | 01:57 PM
97FASTech's Avatar
Veteran: Army
Secondly, I notice it is a LH prop. Did the cup come from a lefty?
Old 09-15-2013 | 02:04 PM
You phucked up...the BLUE cup is for planing, the red cup is for bow lift.
phragle is offline
Old 09-15-2013 | 02:10 PM
you cant go wrong with a RED SOLO CUP,
mike tkach is offline
Old 09-15-2013 | 02:11 PM
Rotate the cup 90 degrees counter clockwise. That should help pop it up on plane faster.
MILD THUNDER is offline
Old 09-15-2013 | 04:07 PM
Yep..... need better tape.... DUCK Tape should do it!!!
Other than that, looks good to me!
Tim Bostic
Tim Bostic is offline
Old 09-15-2013 | 04:09 PM
Tim Bostic
Hey Tim, spoke to you about a year or so ago, in regards to you guys developing another offshore style prop. Any updates on that?
