Go Back  Offshoreonly.com > Owners Forum > Donzi
Hatch Actuator >
Hatch Actuator
Hatch Actuator
Old 09-16-2013 | 04:24 AM
MarkDonzi's Avatar
Default Hatch Actuator
hi Guys,
05, 38ZR and my hatch will not open. I just recently found the wiring schematic for the "Ultraflex" actuator used on the boat. I am going to check the switch on the dash panel first. Anybody else run into this problem? If so were you able to manually open the hatch? Has anyone seen where Donzi mounted the relays for the rams?
Any help would be appreciated!
Thanks, Mark
MarkDonzi is offline
Old 09-16-2013 | 06:23 AM
that i dont know, but if your going out to the marina this weekend i could give you a hand..
prostock3 is offline
Old 09-18-2013 | 04:26 AM
MarkDonzi's Avatar
Hoping to be there Saturday AM depending on the weather. Going to check the switch first, then maybe try to manually open. Hatch is heavy! Thanks for the help!
Old 09-22-2013 | 01:32 PM
MarkDonzi's Avatar
Got lucky, Wire came loose from the switch. Hatch works fine now!)
