Mirage vs mirage plus?
Hey guys I have a Formula 303 Sr1 with twin 502 EFI's and Bravo 1:36 drives, currently twisting 23 Mirages, Wondering what you hink a set of plus's will do, same size, or should I jump to 25's, currently if I go for gold it spins 51/5200 rpm's I think I want to be below 5000 r's, best ever is 77 on Gps, pretty much always runs 74,
thanks
thanks
Testing the 25 M+'s makes sense. You may need to Lab Finish them to get where you need to be.
Brett
Brett
[email protected]
[email protected]
Hello,
The Mirage Plus as the name implies, has more cupping than the original Mirage and will generally turn 200-300 less rpm in the same pitch. If you go to the 23" Mirage Plus's, your rpm will drop 200-300 anyway. The other option is to find a good used set of 25 Mirage's, not Plus's.
Thom
Thom
