Drives to deep?
that doesn't make any sense the propshafts are 8" below the cavitation plates and the trim rams are above the cav plate. how can the shafts be 3 inches below the boat bottom and the trim rams be kicking up spray? Maybe you can post a picture.
regardless it wont stop you from spinning 4 blades as long as they are the right pitch.
We're these the original drives? You have transom water PU's so it seems likely the drives were originally TRS...correct? What boat is this? Length? BBC or SBC power? If the drives are too low, the fix is likely big $$$...either shorter lowers or a total re-rig. If you can get on plane with 3-blades, on most boats you will trade off top end MPH with 4-blades.
4 blade props require more trim,,trim th drives out just until you hear the props brake loose a tiny bit then ease into it andyou may have to drop the drives a tad ..try it and get back to us
