Warlock Tunnel Hull Question >
Old 09-18-2013 | 05:17 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Question Warlock Tunnel Hull Question
I have some questions as to the design of my 25 SXT cat . There is something that looks like wings or air accelerators at the beginning of each tunnel and I always wondered what they are and what they were designed to do . I haven't seen these on other cat hulls . I also took some pics inside the sponsons and was wondering what the honeycomb material is and what is thought of the layup . It must be strong because this cat has been spun out flipped and run pretty hard most of its life and shows absolutely no stress cracks . I am anxious to learn all I can about this design and I know the teaching talent is here . Thank you , deep
the deep is offline
Old 09-18-2013 | 06:44 PM
The wings at the Beginning of the tunnel would be called "Canards" (Little Wings) they are mostly for looks, does look cool. The pickle fork design in general is from necessity. When a Cat hull stands up on the transom like a Blow over, there's less wing surface to help it blow backwards. imagine if the pickle fork wasn't there, there would be a lot more wing surface to assist in it going over. The tunnel is packing air towards the rear, that's where the weight is and that's where the lift is needed. Make any sense? (I Have Been Drinking )
fastdonzi is offline
Old 09-18-2013 | 08:50 PM
Also, From the Pics you posted the Glass work in that boat is Very Nice.. Where they bonded the hull and deck looks great, and it looks like they used good material. Now for the name of the Honeycomb core I can't remember (CMS )
Old 09-18-2013 | 09:05 PM
the deep's Avatar
Fast Singles Club
Thanks bro , have a beer on me . Also hoping to hear from T2x , Steve1 and glassdave . Yea I know , it has a pod .
the deep is offline
Old 09-18-2013 | 09:16 PM
the honeycomb looking material that is on the outside..?? the fiberglass material or the stuff under the glass? the majority of the boat looks to be layed up with 1708 stitch may,,vary strong and is most likely vinylester resin as well..
the stuff with the holes in it is coremat..(Coremat®
Coremat® is a microsphere filled, random laid, chopped fiber polyester fabric with good conformability, that is used as a laminate bulking and print-control mat. Ideal for adding stiffness to laminates and molds.)
+/- 45degree
Contains double bias(17oz) stitched at 45degrees
along with one layer of 3/4oz mat.
Thickness: 0.044"
1708,,,
FIXX is offline
Old 09-18-2013 | 09:52 PM
the deep's Avatar
Fast Singles Club
+/- 45degree
Thickness: 0.044"
1708,,,
Thanks brother Fixx . I'm a gear head and know next to nothing about layup materials and their strength . I can see honeycomb shapes through the glass and was curious if that is what most hi performance boat builders used at the time and why . Circa 1999
the deep is offline
Old 09-18-2013 | 10:00 PM
timewarp's Avatar
The things on the front of the tunnels that you are calling wings were designed in there to help avoid stuffing, the theory is that they will impact the water and force the bow back up out of the water due to the angle they would hit the water at.
timewarp is offline
Old 09-18-2013 | 10:11 PM
the deep's Avatar
Fast Singles Club
Anti stuffing device , good idea . I wonder why no one else uses that design . Would these cause the hull to become unstable at a given high speed , looks like they would create lift and not only upon stuffing . The boat currently runs 83gps as if on rails .
the deep is offline
Old 09-19-2013 | 12:37 AM
what is most likely under the 1708 is woven roven,,tuff stuff..(Coarsely woven fiberglass roving used for fast buildup in applications where cost savings are a factor. Best in flat or only gently contoured surfaces.) this stuff is hard to wet out so it also adds a lot of stiffness to the boat..i believe all the old technologie is being used still but adapted to the new vacuum bagging system..
Anything you need to knoe you can find here..http://www.uscomposites.com/
FIXX is offline
Old 09-19-2013 | 05:09 AM
+1 Looks real good...especially in the location it is at. Some glass monkey had to climb up in there with the materials and lay it.
JRider is offline
