bravo re-install
Old 09-21-2013 | 10:12 PM
Default bravo re-install
i pulled by bravo drive off my tantrum a few months ago to pull the motor . got the motor re-installed last week with the exact same mounts , coupler , spacers etc . we tried to put the drive back on today but its not slipping all the way on . it will start over the bolts but will not go the last 3/4 inch or so .by looking at the grease on the splines it looks like its starting in the coupler . also the prop wont spin once we get it started .... any ideas ? i know someone out there is going to say i have rotten stringers and my mounts arent right , my stringers are fine so dont feel the need to tell me otherwise . i appreciate any help
state1310 is offline
Old 09-21-2013 | 10:39 PM
Offshore style mounts? Could loosen them and hang the motor while sliding the drive on or drape a rag over the drive to protect it and hit it with a big block of wood. Sometimes it just takes a little force. The "dream" of it sliding right on doesn't always happen.
Unlimited jd is offline
Old 09-22-2013 | 12:05 AM
does the alignment tool go in and out easily??
phragle is offline
Old 09-22-2013 | 01:26 AM
Check the alignment with the tool like phragle said. My friend had the same problem this past spring. Looks aligned but it isn't. The gimble bearing might have moved a little and it is preventing the drive from going all the way in. Doesn't take much. Just an idea. Good luck.
dba1062 is offline
Old 09-22-2013 | 02:15 AM
Had my engine out 3 times in 4 years.. lol. Red is likely correct here, your rear alignment is probably off a bit, try lifting it a with a bar or something.. I forget a thin washer they'd used on my rear mounts and drive wouldn't go on. Looking thru the gimbal with a flashlight revealed the alignment problem, checked in the parts box and BINGO, problem solved.
-K
kidturbo is offline
Old 09-22-2013 | 07:10 AM
ok I think your stringers are rotten,,,lol,,
had that happen numerous times,,if its just the last 3/4" that wont go in most likely its the 2 larger o rings on the shaft binding when they hit the gimbal bearing,,
you can verify this by removing the o rings and try installing the out drive I bet it will slide all the way in,,,I just start a nut on each side and slowly tighten evenly and it goes right in..
if it was the alignment you would not be able to push the outdrive that far in..
the prop does not turn because your in gear
boatnt is offline
Old 09-22-2013 | 07:52 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Did you replace the gimble bearing too? Are you sure it's seated all the way? This will also cause the same condition.
Sydwayz is offline
Old 09-22-2013 | 08:36 AM
Try using scotch brite pad and polish the drive shaft where the gimble bearing sits .
lskaracing is offline
Old 09-22-2013 | 08:42 AM
Tinkerer's Avatar
If the alignment tool slides in and out with TWO fingers the drive will slide right in also. YOU should NEVER have to force it on. If you have to use force something isn't right. Engine couplers are not cheap and the engine has to be removed to replace it.
Tinkerer is offline
Old 09-22-2013 | 09:01 AM
Seeing as you removed your engine there is a good chance your coupler is not aligned properly and is stuck. Slide your alignment tool in and bang it on all four sides with a rubber mallet to set it in position. This should allow your bar to slide with just two finger. If is is still tough to move, put alittle film of grease on the end and slide it in and out with out rotateing, this will show where your splines are hitting and which way the engine has to move.
If you dont have an alignment tool, DON'T INSTALL THE DRIVE!
Katanna is offline
