What is the best drive shower for this setup?
Livorsi sells one that works like a Simrek, but IMO has way better water pick ups. It will only work on a std length drive as I found out. The only thing I would check is that since it has 2 water pick ups, is that it has a wall between they so they are not fighting each other. I corrected that issue with my Simreks.
What did you do to fix? Got any pics?
