Por 15
Old 09-29-2013 | 01:54 PM
Craney's Avatar
Default Por 15
Has anybody used this to paint their outdrive or anything else??
Craney is offline
Old 09-29-2013 | 02:23 PM
It is excellent rust control paint but does not do well in direct sun, undercarriages and metal areas hidden from sunlight, UV rays break it down..... ;-)
FogduckerIII is offline
Old 09-29-2013 | 06:35 PM
glassdave's Avatar
Neno the mind boggler
don't . . . under any circumstances . . . get it on ya . . .
08 OPA High Points Champion
glassdave is offline
Old 09-29-2013 | 06:58 PM
bwd
or spray it without protection.
bwd is offline
Old 09-29-2013 | 11:56 PM
Not to hijack, but what would you guys recommend for the "best" gloss black outdrive paint? I was thinking PPG automotive, but it's not really meant to be subjected to the rigors of what an outdrive like a Bravo encounters. All I know is the mercruiser stuff is garbage....
Borgie is offline
Old 09-30-2013 | 12:30 PM
glassdave's Avatar
Black single stage Concept from PPG
Old 09-30-2013 | 01:30 PM
I have used por 15 on motorcycle parts with good results. quick question for Dave ... What do you use for nonskid in cockpit ?
mptrimshop is offline
Old 09-30-2013 | 02:26 PM
glassdave's Avatar
kinda depends on what finish i am looking for. I generally use a waxed gel with a fine non skid added. I have also used Gibco flex mold with fantastic results but it is expensive.
Old 09-30-2013 | 08:46 PM
2nd hyjack������ I want to paint out drives to match the brushed aluminum hardware I have... Monster tab, vents, handles, etc.... Would you use the PPG single stage Concept?
stormbauer is offline
Old 09-30-2013 | 09:18 PM
por 15 works but need to use all the proper wash and primer or it just peels off like a bad sunburn. I used amour coat rust paint lasts longer and is cheaper. agreed that the merc spray bomb paint is garbage!
Scorp260sting is offline
