XR upper gear set inspection >
Old 10-05-2013 | 07:06 AM
Default XR upper gear set inspection
I have about 100 hours on my XR that has had about 750 hp in front of it and I what to inspect the upper gear set, can I remove the upper rear cover that the steering rams hook to and see the gear set? I have change the oil about ever 15 hours and have had no metal in the oil or on the magnets but I still would like to take a look.
Thanks John
sport is offline
Old 10-05-2013 | 02:19 PM
No. You will have to completely take the drive apart to see the gears.
Griff is offline
Old 10-05-2013 | 05:02 PM
You can inspect the driven gears and get a good idea of condition by just pulling back cover of upper
motor is offline
Old 10-06-2013 | 12:04 AM
You can see them, I guess, but really can't see them well enough to be able inspect the wear patterns and evaluate whether there might be problem approaching.
Griff is offline
Old 10-06-2013 | 08:47 AM
1 MAIDEN AMERICA's Avatar
At 100 hours with 700HP, REPLACE them. At 105 hours I broke a set. 1 tooth came off, seized the drive, broke the coupler shaft in 3 pieces and twisted the heck out of the coupler. The rest of the teeth looked about new. Absolutely NO pitting and just a slight shine. You can sell the used gears to recoup some money.
1 MAIDEN AMERICA is offline
