04 sonic electrical problem >
Old 10-17-2013 | 08:00 AM
Default 04 sonic electrical problem
i recently bought a 2004 prowler 26 496ho and am experiencing a draw on the batteries and overnight they are completely drained. I was wondering if anyone had some insight on troubleshooting this situation. I have noticed with the key off and just the batteries on the ignition wires on the starter are warm when the motor hasnt even been started or key even turned on. I am also experiencing problems where it sounds like the starter is getting low voltage when cranking. I have 2 brand new batteries and it looks like the previous owner installed an ignition switch ( not mercruiser ) if that matters. Not sure where to go from here any help would be appreciated.
04sonic is offline
Old 10-17-2013 | 08:02 AM
A test light and multi meter will go a long way here . You need to start probing around.
MILD THUNDER is offline
Old 10-17-2013 | 09:00 AM
check with merc i read on the net that some 496 pcm had diode problems on the ignition circuits .
tazdevil is offline
Old 10-17-2013 | 09:11 AM
Sydwayz's Avatar
Forum Regulator
Is the aftermarket starter switch a marine unit? If not, I would not be surprised if it has corroded and is causing some or all of your problem.
Check the major fuse breakers under the back seat to make sure there is no fault there.
Also, make sure to check the battery switch. They can go bad.
Sydwayz is offline
Old 10-17-2013 | 06:48 PM
Thanks guys will check some of this stuff and start probing around tomorrow.
04sonic is offline
Old 10-17-2013 | 09:32 PM
First turn everything off like you would leave the boat overnight. Disconnect the negative battery cable, connect the cable to the battery with a test light (it should light up if there is a draw).
Now start disconnecting things, pulling fuses, one thing at a time until the light goes out - thats the circuit that has the issue
sailtexas186548 is offline
Old 10-17-2013 | 09:35 PM
I agree. Place the test light between the disconnected neg cable and neg battery terminal.
Old 10-18-2013 | 12:30 PM
This will work unless the load is to great - and blows the bulb in the test light. I use an ammeter when tracking down parasitic drains. Most newer DVOMs have a fused ammeter on board.
ALL_IN! is offline
