(NON)Mercury Racing Blue Bomb can? >
Old 10-17-2013 | 12:03 PM
Default (NON)Mercury Racing Blue Bomb can?
So has anyone put together a home-grown solution to the avoid paying $40 a can for Merc blue from Merc? To me that is gouging! I know there are paint codes available but I dont want the hassle of using a gun.
I did some poking around and found this:
http://www.artoo-detoo.net/gallery/v...test1.jpg.html
Be sure to check out all the links on the left hand side.
If nobody has came up with a paint or paints that will work I am going to test some paints soon.
JRider is offline
Old 10-17-2013 | 01:00 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It's been done before. Do a search on "Raypanic blue" and you will get the thread results. This was a while back; and not sure if it's still available.
Sydwayz is offline
Old 10-17-2013 | 01:10 PM
I had this on file from probably 10 years ago, but can't remember all the details. Maybe the OSO paint gurus can break it down. Sorry I could not be of more help.
OR
Merc Blue motor paint
dupont code B8110A General Motors code 20 1981
Bright Blue-Effect
to mix 48 oz imron (2 qts)
531U LS BLACK 40.6
521U ALUM 100.3
565U RED 357.9
559U BLUE 731.2
572U CLEAR 1053.8
570U LO VOC BINDER 1381.9
8585S REDUCER 1409.0[/B]
OLDRAT is offline
Old 10-17-2013 | 01:52 PM
As a Napa auto parts we can still match the Hyundai paint code "HD" (which is supposedly close). At my location we can put any sprayable toner into a rattle can. I could mix one up and do a spray out then all you guys would have to do is go to your local Napa and have them mix a spray bomb with that formula.
TylerBurich is offline
Old 10-17-2013 | 04:04 PM
Sounds good
mptrimshop is offline
Old 10-17-2013 | 09:46 PM
Find an Oreilly that mixes paint if you have a dupont code they can put it in can for you. If you are in MN they can mix it and send it to any store.
professor_speed is offline
Old 10-19-2013 | 09:30 AM
I found cobalt blue metallic (rust-oleum) from home depot is really close. And for $5 a can, the diff in metallic is fine
carrera1 is offline
